This command displays the count of PTP packets that include event messages, signaling and management messages transmitted and received on each unicast-slave/unicast-master peers. Use the following queries for the counters:
The refresh option is not supported for the counters. This command is available only for Boundary and Ordinary clocks.
| network-clock | External clock for ethernet synchronization. |
| ptp | Precise time protocol. |
| boundary | Boundary clock. |
| ordinary | Ordinary clock. |
| vlan | VLAN. |
| ipv4_address | Peer IP address. |
| unicast-master | IP addresses that are masters to the local clock. |
| unicast-slave | IP addresses that are slaves to the local clock. |
| all | All VLANS. |
| counters | PTP message counts. |
N/A.
Use this command to display the count of PTP packets that include event messages, signaling and management messages transmitted and received on each unicast-slave/unicast-master peers.
# show network-clock ptp boundary vlan lpbk-gm 1.1.1.101 unicast-master counters VLAN name: lpbk-gm Peer IP Address: 1.1.1.101 IN (packets) OUT (packets) Message Type ================== ================== ============= 211 0 Announce 27041 0 Sync 0 0 FollowUp 0 26532 DelayReq 26489 0 DelayResp 0 0 Management 141 150 Signaling 0 Rejected # show network-clock ptp boundary vlan all unicast-slave counters VLAN name: lpbk-slave Peer IP Address: 15.1.1.1 IN (packets) OUT (packets) Message Type ================== ================== ============= 0 258 Announce 0 32958 Sync 0 32958 FollowUp 0 0 DelayReq 0 0 DelayResp 0 0 Management 0 0 Signaling 0 Rejected VLAN name: lpbk-slave Peer IP Address: 15.1.1.2 IN (packets) OUT (packets) Message Type ================== ================== ============= 0 258 Announce 0 32960 Sync 0 32960 FollowUp 31569 0 DelayReq 0 31569 DelayResp 0 0 Management 166 0 Signaling 0 Rejected
This command was first available in ExtremeXOS 15.2.
This command is available on 7520-48Y and 7720 platforms.
PTP commands can be used only with the Premier license pack.
